remove autocomplete
fsas06
Oct 15, 2007
604
Las Vegas
u need to be jailbroken and there was some kind of tweek that gives u more options under settings but I'm not sure if its still out or what its called I seen it awile ago
many someone else can give u the name
bemania
May 26, 2008
14
29
Switzerland
www.meridia.ch
re
thanks for the reply. i got it jailbroken already. then i only need the name of the app.:(
i thought it would be really easy to solve this problem, because on other mobilephones it can be done easily.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
The program is called KB and it used to be under Tweaks in Installer. I haven't checked if it is still there or not but here is a link to the appcat site showing the source:
http://iappcat.com/apps/info/app/71
Update: I just looked in my installer and it is still there under Tweaks.
bemania
May 26, 2008
14
29
Switzerland
www.meridia.ch
Thank you very much. That solved my problem.
