removing redsn0w 0.9.10b6
magnet513
Nov 10, 2012
Hey guys im currently running into some issues with my iPhone 4 refusing to connect to AT&T so i cant receive calls, texts, or emails. Because of this issue i need to restore my phone but iTunes keeps stopping the process saying my phone isn't eligible for the requested build. I have tried restoring out of DFU mode several times, ive tried changing the cydia settings on tinyumbrella and ive tried restoring to the OS im currently running (5.1) and all have failed. any help I can get is greatly appreciated.
Do you have an SHSH for the firmware version you're trying to restore to? Make sure you check the 'set hosts file to Cydia upon exit'' box in TinyUmbrella.
magnet513
Nov 10, 2012
ok but im trying to restore it period. ive tried restoring to 6.0.1 and i got the same error.
Make sure you uncheck the 'set hosts file to Cydia upon exit' before restoring to 6.0.1.
Also, make sure you are using the correct firmware for your iPhone 4. You'll get that error if you try to use the CDMA version on the GSM iPhone or vice versa or if you try to use 3GS or 4S firmware.
fijiman
Feb 13, 2011
832
64
UK
Use the latest redsn0w 0.9.15b3 ....
As Europa said without saved SHSH blobs for 5.1.1 you can't restore to 5.1.1
You can use redsn0w to downgrade or upgrade your firmware without using iTunes...
