Removing Silverback Plate on iPhone
Rex32
Nov 29, 2007
Hey Everyone,
Just wondering if anyone knows if removing the silver back plate will void my warranty. I figure I don't have one anyway since my phone is all dented up, but I want to try to push part of it back in so the top will all snap together...
How would Apple know if I removed the back? Just looks like 3 screws from the videos I've seen.
Anyone done it themselves?
Thanks,
Mike
depthnerd
Feb 16, 2008
1,280
Did you really think the case separator tool was necessary or were you able to get the black piece off another way?
I got it off another way but I had wished I used the separator tool. My way was truly a pain in the ass.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
seperator tool is a ripp off. That tool is only good for a
couple openings before its worn out. Its softer than the metal on the iPhone so that it won't scratch the case but that also means it wears out after a couple uses.... Complete ripp off. Find something else, anything else. Properly a
hundred things infront of you right now that have an "edge" to them....
