Removing Vibration when plugging in for charging
kwan
Jul 7, 2007
88
Is there a way to remove the vibration you get when plugging the phone for charging?
My phone with the InCase charger case vibrates several times at night when plugged in.
Saverino
Jun 1, 2008
4,480
92
Burbank
Napo- Yes, but then it won't vibrate at all.
The OP only wants the vibration off when the phone is plugged in, from what I understand.
freakydeaky dutch bastard
Dec 10, 2007
710
blacked out
I'm confused. Is it vibrating because you're receiving a txt or phone call, or is it doing the "double vibrate" thing you get when you plug the phone into a power source?
If it's doing the later, it sounds like your not making a solid connection with the "InCase" charger.
kwan
Jul 7, 2007
88
Thanks for all the responses.
The problem is when using the InCase Charger. When the battery is drained on the Case, it goes through several charging cycles where the phone "thinks" its being plugged in again. This usually happens at night when I have it on silent/vibrate and the vibration gets quite annoying.
I've tried turning off both of the vibration toggles, but it removes the vibration from everything except this.
My last resort would be to charge them separately, but I'm trying to avoid that route.
6,683
50
AS of right now, there is no way to disable the vibration from "connecting to power source"
I am afraid you are just going to have to deal with it.
kwan
Jul 7, 2007
88
Solved
I found a solution. There is a File under /System/Library/PrivateFrameworks/Celestial.framework/ named SystemSoundVibrationPattern.plist
There is also a Haptic Keyboard modification that replaces this file and allows for feedback when pressing the keyboard. I just edited that file so that the vibration upon charging is so brief that you can't notice it unless you have a stethoscope on it.
If anyone wants this file to modify their keyboard "feel", I'll give you the link.
Dec 10, 2007
710
blacked out
well hot-diggity-dawg, kwan. excellent sleuthing, I say.
Philmadrigal
Oct 4, 2012
On iOS6: Go to Settings > Sounds> Ringtone > Vibration (change the value to 'None')
Damien A
Feb 7, 2013
What you could've done, as a simple solution, is turn the ringer all the way down, put your phone on ring, and than plugged headphones into the phone. No noise, no need to screw with files.
dapurplenurple
Jul 8, 2009
92
If you're using Winterboard, you can load up "Silent Charge Classic" to prevent the ringer (or vibrate when on silent mode) at the detection of AC power. Haven't tested it since I'm not currently using Winterboard.
