ReOrder Notification Widgets
Lon
Jun 5, 2010
2,946
132
Alaska
Is there a way to change the order in which widgets appear in the Notification Center? I can't seem to find a way to do it.
Sent Using iCafe App
Kadelic
Jan 4, 2010
4,947
1,646
Dallas, TX
In Settings>Notifications tap Edit and you can rearrange the order of the apps. Is that what you're looking for?
Edit: Also, it appears you have to "Sort Apps:" set to "Manually" to get the notifications to arrange in the order you set.
Lon
Jun 5, 2010
2,946
132
Alaska
Thanks. I did set it to Manual. At first my screen kept sliding, but I finally got the widgets to slide. Perfect
