Reset network setting "bricked" iPhone 6+
shutter13
Jan 8, 2009
2,201
144
So my daughter an I were receiving the same phone calls, and by that I mean the exact same phone calls. If my son or wife called either of us, both our phones would ring. I decided to reset network settings on bth phones, my daughters (iPhone 5S) went through without a hitch. mine (jailbroken iPhone 6+), not so much, when it rebooted it stayed on the apple logo. I tried hard resetting it a few times and ended up putting it into DFU and am restoring it at the moment. It's too bad, I'm going to lose about 2 weeks worth of info, maybe that will teach me to back up more often.
shutter13
Jan 8, 2009
2,201
144
regular cellular phone calls. Her iPhone 5S was my phone before I got the 6+, but that phone had a full restore done on it and got a brand new SIM card.
28,365
5,506
You didn't need to reset the network settings. There is a really simple fix for it. It's the default iOS 8 setting to route all cellular calls to every iOS device that is logged into the same Apple ID. It does this through FaceTime with the new FaceTime audio-only feature.
To fix the problem, on your daughters phone:
Go to Settings > FaceTime > iPhone Cellular Calls > Toggle it off
You can toggle it off on your phone as well, but you'll want it on on your phone if you are routing calls to your Mac. I turn it off on my iPad and old iPhone but leave it on on my new phone so I can get calls on my Mac.
Side note: That's unfortunate that resetting network settings caused you to have to restore. It was just a fluke. Typically you can reset all settings and network settings on a jailbroken phone without problems.
