Restore error 3004
soosb21
Nov 2, 2007
54
just deleted the iTunes i had and downloadin and installin newest one from iTunes gonna try that. lol its killin me stuck in dfu with a brand new phone
iphun
Mar 16, 2009
1,967
PA
If that doesn't work shut the phone off and put it into DFU yourself - have iTunes open turn the phone off then hold the home button while you connect to the computer. Then iTunes will recognize a phone in restore mode and hopefully you won't fail.
iphun
Mar 16, 2009
1,967
PA
It doesn't sound like it will be too much longer for the 3.0 jailbreak, but I am sure it will take a little longer for the 3GS
Jul 2, 2009
I'm having same issue and yes Im familiar with DFU Mode. My iPhone 3G S gets 3004 error when I try to restore it in DFU mode or regular Restore mode and now It wont go back to normal phone. Its stuck in Restore mode. Any ideas? (Besides take it back to Apple)
28,365
5,506
Please provide a little more information. At what point exactly in the restore process do you get the error? PC or Mac? iTunes version?
Try deleting the ipsw file (maybe it's a corrupt file?) and then restoring again. iTunes will automatically redownload it after you delete it and then restore to factory settings.
Here's where the file is located.
On Windows:
Documents and Settings\<User>\Application Data\Apple Computer\iTunes\iPhone Software Updates
On Mac:
~/Library/iTunes/iPhone Software Updates
mymobile
Jul 2, 2009
I had the exact same problem.
The solution for me was :-
1. Download iTunes 8.2 from Apple.com
2. Install the downloaded iTunes - this will install over the 8.2B (beta).
3. do the normal restore with the 3.1 FW
FIXED IT FOR ME!
