Restored other persons settings by plugging to their computer
Craigmac
Jan 26, 2013
Today I plugged my iPhone into my friends computer to charge it and all of a sudden I have all of his contacts,pictures,email settings, and all of mine are gone. I would like to get my phone back with all of my information and not his. I never backed these things up on iCloud. Is there any way to re restore my phone to the way it was? Please help
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,924
1,984
Resync it on your computer. IF you mean you have never synced it before, your in for a long haul....
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
I'm betting he had iTunes on his computer set to NOT prevent automatic syncing of devices. Do you have a recent iTunes backup of your device on your computer? If not, his iTunes should have backed up your existing data prior to syncing his data to your phone. You might try going to iTunes on his computer, go to preferences>devices> and check the box that says "prevent (devices) from syncing automatically." Then plug your phone in, right click on it in the device pane, and select "restore from backup." Then look to see if there is a backup file for your phone and apply it. I hope this helps and you are able to get your stuff back!
Craigmac
Jan 26, 2013
I tried what you said Kadelic but when I go to iTunes and click on my iPhone there is not a restore from backup option, only a delete backup option underneath the window where the devices are listed. Does this mean there is no backup or is the backup hiding somewhere? Thank you for your first response. Now I at least think it might be in my friends computer somewhere and I might be able to get it back. Let me know what you think. Thanks again
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
I tried what you said Kadelic but when I go to iTunes and click on my iPhone there is not a restore from backup option, only a delete backup option underneath the window where the devices are listed. Does this mean there is no backup or is the backup hiding somewhere? Thank you for your first response. Now I at least think it might be in my friends computer somewhere and I might be able to get it back. Let me know what you think. Thanks again.
Apologies for not getting back to you. Here's a link that shows you where to look for iPhone backups on Mac and Windows: http://osxdaily.com/2009/09/11/iphone-backup-location/
