Restoring an unlocked iPhone
mfb
Nov 30, 2007
hey there, i am new to this forum so i thought i start by saying hello to all.
i am using an unlocked iPhone v.1.0.2 .
i want to mod it using installer (apptap) but i m scared it might mess it up so i would need a restore..
but the question is if i restore the iPhone will the unlock be removed ?
and how do i restore it if i need to ?
thanks a lot guys...
Chris716
Nov 29, 2007
807
IL
your best best bet is to go ahead and just install the apps you want. As long as you don't restore or upgrade the phone you will be alright. Also check out the search option there are several great ideas in there about this
