Restoring Apps After a Restore Phone As New
bkushner
Jan 22, 2008
70
I'm having an issue with my phone and Apple wants me to restore the phone as NEW to troubleshoot. Once I do this how do I get my app order back on my phone? I have most of my apps grouped.
talon90
Jan 17, 2009
290
29
If you have iTunes they will sync (and keep your folders in tact.)
If you don't you can download all of them from iTunes via the App Store on the phone under the purchased tab under Updates.
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Very simple now that you can restore from iCloud backup.
Just lake sure you have enables iCloud backup prior to restoring, or u will have to sync with computer.
Also, there are options in iCloud to save specific info for apps.
Very usefull if you have games that save data, such as user, scores and game progress.
For the most part, I do not think it will save location of apps in folders. U have to manually do that after restore....Not too sure on that, been so long since Ive done a non JB restore:D
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
Actually, restoring as a new device means you have to skip the iCloud restore option.
I'm afraid there's no way to save and restore the order of apps or their folders without restoring from a backup. You'll have to manually put them back into folders.
I have thought about that many times, it would be pretty awesome to save a certain home screen layout.
VOLS34
Jun 25, 2010
1,119
79
Go into your App Store app. At the bottom go to updates & at the top there should be a purchased tab that goes across the top of the screen. Click on it & it should show all the apps you have downloaded in the past. At some point you will have to sign in with your Apple ID if you hadn't already. Go down the list & click the ones you want to re-download. It's time consuming & a pain. You will also have to reorganize your folders.
