Restoring my iPhone
Swek
Apr 17, 2008
22
Hi, i need a way to restore my iPhone without a computer... Using installer or something.
My computer won't detect my iPhone so i cant restore it that way. I am having lots of problems with it. Since i jailbroke my iPhone, i need to restore it so i can get it exchanged. i have a 16 gb iPhone with 1.1.4
thanks
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
thanks
You need to put the phone in recovery mode. You do that by holding the Sleep/Wake and Home buttons until the Apple logo appears (about 20 seconds). Release the Sleep/Wake button, and continue holding the Home button until the connect to iTunes graphic is displayed. You may have to do it several times, but eventually it will take.
Good luck
Swek
Apr 17, 2008
22
Good luck
yeah but i have tried that a million times and my computer still does not detect it
psylichon
Oct 31, 2007
16,591
751
40
Philly
Does it also not take a charge via AC? Your dock connector is shot, and there is no way to restore at this point.
Wow this is the third time I've given this advice today. Must be an epidemic:
Let your phone drain to the point that it won't power on anymore then take it back to Apple. If it won't take a charge or light up when docked, they won't be able to tell what you've done with it, and you may get a replacement.
But there is no way to restore without a computer.
Swek
Apr 17, 2008
22
Ok thanks a lot... (but just so you know its actually the second time... I also posted something on the "ziPhone question" thread, so it was me you told to do this:p)
28,365
5,506
Quickly remove it from the water, power it down, remove your sim card (and put it in a disposable phone), and put the phone in a bag of rice for several days (preferrably one week). DO NOT attempt to power it on sooner. This almost always works.
If you didn't use rice or have it backed up in iTunes, it's all over but the crying. Sorry. :(
Apr 7, 2011
Ahhh thanks! The SIM card was salvaged and luckily most pictures were on back-up, but I had acquired many numbers from the past 5 years that I was hoping to safe.....at least for nostalgic purposes!
Apr 7, 2011
Thanks! I will most definitely use this my next go 'round(right now). I feel like such an idiot for not doing it before, but alas I guess you learn from your mistakes.
Kadelic
Jan 4, 2010
4,937
1,645
Dallas, TX
If all the music on your device is also in the iTunes library with which you sync to, then yes, you will be able to put that music back. If the music exists only on your device you need to copy it to your computer and into iTunes before you restore.
