Restrictions to number of iPhones used in iTunes?
Justin
Mar 6, 2007
71
Since you can only use one iPod on iTunes, will the iPhone be restricted to the same limitation?
I already have a normal iPod, will I be able to use my iPhone on the same iTunes I already use?
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
I'd say yes, similar in the way a Shuffle operates. I own both a video iPod and a Shuffle. Both are synced to the same iTunes without a problem.
Justin
Mar 6, 2007
71
That's good to know, I was under the impression any ipod would get wiped out if it was used on an different version of iTunes.
