returning a Jailbroke 3G 16G for repair
Oct 30, 2008
I have restored to the original 2.2.1 firmware, but the ATT identification that should be at the top left is still changed to my name using "make it mine" and I still get numerical battery percent. I thought all modifications would be overwritten with new firmware.
Anyone know how to fix? I don't want to send it back to Apple with software mods.
Do I need to Re-Jailbreak install the apps that made the change and undo it?
BTW I am returning it because it gets very hot.
6,682
49
Yes. you have to jailbreak again and change the carrier and battery displays back to stock, then restore to stock.
iNinja
Aug 8, 2008
3,984
20
UK
You could first try restoring as a new device in iTunes, if that doesn't work, yes you will have to re-jailbreak!
Oct 30, 2008
Tried the setup as new device in iTunes first just because it was easier, and it worked. all appears stock.
