"Revirginizer" released!
akophone
Aug 1, 2007
300
The Elite Team released a "revirginizer" tool. According to them, your 1.0.2 unlocked iPhone will return to its pre-unlocked state and be safe to upgrade to 1.1.1. Some users have already reported success.....
Read more and download link here.
"Some" users? Meaning it hasn't worked for some?
coolie
Sep 18, 2007
131
i have been waiting for this forever. but i don't need it now
akophone
Aug 1, 2007
300
The process is still extremely raw and unrefined, requiring some skill and patience, but has already been successful for a number of users who've followed it in meticulously. MMI is currently working on a guide.
Basically, what the "reverginizer" does is the answer to those whose phones were rendered useless after upgrading to 1.1.1..... iPhones unlocked with 1.0.2, then bricked, can now be upgraded to 1.1.1 and unlocked.
da0ne83
Sep 17, 2007
i tried it and successfully upgraded and unlocked mine after being stuck with a bricked iPhone
used there guide to fix flashband problem then used mmi tutiorial to jailbreak/activate/unlock with 1.1.1
http://www.modmyi.com/forums/showthread.php?t=11817
not for just anyone to try you really need to know what you are doing or wait till and gui comes out
redstar299
103
help
After I try to runthe norz script it just says "waiting for data" and hangs - any suggestions?
Stevonw
Sep 14, 2007
560
UK
This happened to me the first time i attempted, you baseband could be lost as you have 2 exit. (Meaning no calls, wifi etc)
DO NOT PANIC
Simply do an iTunes restore and start again! :laugh2:
redstar299
103
Yes I restored and it works. Did you try the revirginizer again and did it work or there something I am missing and it will happen again?
Stevonw
Sep 14, 2007
560
UK
Don't install SSH via iNdependence (as it f**ks the process up).....use Open SSH through installer.
Are u Windows or Mac?
redstar299
103
Hey
That's what I did - I used the open ssh through the installer...I did it via mac but have a windows laptop too and and use that to fix if anyone can help
Stevonw
Sep 14, 2007
560
UK
Hey
I'd advise against using the guide on the Google code page and use THIS METHOD instead
as it worked for the 2 phones i done only a few hours ago on my Mac Mini.
After restoring my iPhone to a "Virgin" state i then used iFuntastic and used it for the "one click upgrade/jailbreak/springboard patch". It's excellent, i used iNdependence to activate :D
Hopefully you suceed this time :laugh2:
Good luck mate!
redstar299
103
thats the one I used- uughh this is so frustrating.. is there anything else u did besides this? maybe i am missing something
Stevonw
Sep 14, 2007
560
UK
don't think so mate. are u sure you are copying everything directly and that u have set all the file permissions to 755 (otherwise it won't work and could freeze)
redstar299
103
which programs are you using to unlock and activate? Lets say I restore from scractch - what are you doing first?
Stevonw
Sep 14, 2007
560
UK
The only reason i had to virginize my v1.02 phones is because i had used anySIM V1.02
The upgrade to v1.1.1 i used the 1 click upgrade through iFuntastic
Unlock i used anySIM V1.1
Activation i used iNdependence
redstar299
103
ok im gonna try after dinner and report back - thanks for your help
