ringtone 7.4.2 wipedout all my ringtones so
the watcher
Jul 5, 2007
183
if anyone figure a new way around it pls post sharing in caring
cdinca
Jul 4, 2007
397
Actually, if you read the entire thread at that url you will find that the "fix" only puts the ringtones into the ringtone folder in iTunes but does not sync to the phone.
yeah...they thought it worked...but no go.
chris07
Jun 30, 2007
145
i don't get how you gyes are loosing your ringtones with the past few updates?
i never used any software to upload my ringtones so maybe thats why, i do it the original way because i like it better and under ringtones in iTunes i juss UNCHECK the sync ringtone box and i haven't had to reinstall my ringtones yet or anything.
Just wondering what you people with the non iTunes ringtones are going to do with future updates that add features? Are you going to skip them just to keep your ringtones?
I don't think they are worth the hassles you are putting up with.
termleech
Sep 7, 2007
1,154
McPherson, KS
I don't understand why people are trying to sync ringtones either. Obviously every time Apple releases an update they are going to try and break it (much like they do DRM). The easiest way I've found which has worked since I got my iPhone and through the most recent updates is to use iFuntastic and just copy the ringtones I want to the System Ringtones directory. This way they are there and any updates shouldn't break it unless Apple puts in some kind of protection for System ringtones.
greenjbhsd
Jul 13, 2007
571
I think the important thing to remember here is not to update for the sake of updating. The versions of iTunes since 7.3.1 have not added any features that I know of for people that are using outside programs to add ring tones. I have had custom ringtones on my phone for a while and have never had them deleted/moved/renamed because I have not touched iTunes. From this point forward the only time I will update iTunes if whatever firmware update comes requires it.
