ringtone maker?
Bryman
May 30, 2009
224
colorado
i guy i work with uses this site
http://iringer.net
i looked at it, and it seems like a scam lol. anyone use it? i was under the impression you couldn't do custom ring times unless jailbroken?
jpm
Aug 5, 2007
212
Can't say anything about that program as I have never used it, but you don't need to jailbreak to get free tones. Search the forum and you will find a thread on how to do it.
Bryman
May 30, 2009
224
colorado
i searched and fhave just finished making my first ringtone. thanks lol
connie
Jul 11, 2007
2,839
105
So Cal
I have used both iPhoneringtonemaker and Audiko.net, and now that I have a mac I use Garage Band, but both the others have worked well for me in the past.
partizan
Feb 25, 2008
302
Milton, Ontario
I've been using iRinger for a while now, no issues at all. Very simple, easy to use program.
ipanema
Sep 24, 2009
Yap iRinger clean and easy to use
6,682
49
juls1585 said:
I don't use any programs to make ringtones? Its just a simple few steps in iTunes and changing the file name and youre done.
The reason people are using apps or software is because ringtones have to be under 30 seconds. Renaming the file extension, only gets you so far.
Now if you have a 30 second clip and you convert it to ACC, then just changing the file extension is all you will need to do. Otherwise you need to trim the length.
