ringtone ... wavepad ?
foamtech
Oct 30, 2007
39
Hi ..i am still useing 1.0.2 version and i been trying to add ringtones to my iPhone but after i download wavepad ..i could not get the software to convert form m4a to m4r ..please tell me what do i need to do to converte it or if there is other software that i need to use ..thanks a lot ..
First use wavepad to cut down the ringtone to what you would like.
Then in iTunes, go into the Preferences, and make sure that in Advanced > Importing, your import settings are set to 'Import using AAC Encoder'. Then import your ringtone into iTunes. Next, right click it, and select Convert selection to AAC. Then place the converted file onto your desktop and rename it's extension to .m4r.
It sounds like it takes a lot longer that it really does.
- John
foamtech
Oct 30, 2007
39
thanks again ..i have done all those steps and i have the ringtone in my itune librert the only problem that i have is in the ringtone folder is still empty even ewhen i got the file named as ringtone mr4 ...
- John
iToner does work with 1.12. It is Shareware, however you can download it as an unlimited trial. The only thing different about the registered version is that you do not have to wait 30 seconds before your ringtone is uploaded.
- John
