ringtones and Outlook express
Sep 12, 2007
14
ok i haven't got an iPhone yet but i want to hav everything ready when i do.i hav ringtones from my krzrs removable memory that i put on computer stupid stuf not songs so i couldnt buy then on iTunes if i wanted to.so i put them in my iTunes library like songs.can i assign them as ringtones on my iPhone?and has anyone used outlook express 6 to sync contacts to iPhone?possible?
thanks
420greg
Jun 26, 2007
845
Orlando, Florida
Yes and yes.
You will have to hack your phone to get no iTunes store ringtones on it but it is not very hard.
You can even sync them to your iphen as mp3's and use a 3rd party app called SongSend to 'send the song' to you ringtone folder.
Once they are in your ringtone folder you can assign them to any contact.
Un check 'sync ringtones' on the ringtone tab in iTunes or you will lose them.
