Ringtones issue! :(
wozskillz
Nov 16, 2007
Hey Guys
well these are the steps ive taken...
Cut song to 20 seconds in iTunes, convert to ACC which made a copy of the song and i edited the name to ringtone, i then dragged the 20 second ACC file to desktop changed the file extension to .m4r and the icon changed to ring, then double clicked on it and it showed in ringtones folder ticked the song to sync in ringtones and once my iPhone had synced i checked and there is nothin there, however when i go into my ipod sections on iPhone the song is in there 30 seconds long ... pls help me out here, or if anyone has msn that can give me some support be great.
Cheers
faseone
Oct 2, 2007
203
what version of iTunes and what version of firmware...
This works with iPhone 1.1.2 and iTunes 7.5
wozskillz
Nov 16, 2007
I cant double check right now cause im at work, but it's the latest update as i checked last night, and it said i had the latest version on iTunes.
faseone
Oct 2, 2007
203
what program are you using to clip the song down....don't clip it in iTunes
start with a .mp3 file clip it down to 30sec and save as .mp3 (I use Adobe Audition 1.5)
then add that .mp3 and convert it to AAC
you should now have "ringtonename.m4a"
change the extension to .m4r and click it to add to Ringtones folder
Sync
wozskillz
Nov 16, 2007
So i must download adobe audition first to clip the song to 30 seconds? can you add me on msn mate... u sound like u know what your talkin about woz87@hotmail.co.uk
cheers!
psylichon
Oct 31, 2007
16,591
751
41
Philly
Edit: you may be doing this... hard to tell from your description:
I think the problem is you're not syncing it as a ringtone. When you have your iPhone connected to the computer, go to its tab in the devices section in iTunes (on the left), go to the ringtone tab (at the top now), and make sure you have your custom ringtones checked for sync.
ai1973
Nov 17, 2007
Sync
:laugh2: thanks for this works great on my pc:cool:
