Ringtones now Available on iTunes.
chavezr6
Sep 9, 2007
Just loaded up my iPhone and little message came up asking if I would like to see what songs on my list are available to make into ringtones so i clicked yes and now there is a little bell with the ability, I assume, to do this.
n_kat
Jun 6, 2007
44
Oregon Coast
Hummm.....I just put my iPhone in its dock, checked for updates for both iTunes and iPhone and I didn't get this message. bummer!
minivini
Jul 6, 2007
418
keep checking. I just docked and got the message...
mediarite
Jun 20, 2007
97
ColoRADo
Right-click on the header bar across the top of your music library and select Ringtones
minivini
Jul 6, 2007
418
not one of our 4000 songs is available as a ringtone? that can't be right...
:confused:
mediarite
Jun 20, 2007
97
ColoRADo
27 songs of the 3000 in my library were authorized for ringtones. I created one. It worked well. I now have a Ringtones library at the top left of iTunes. Now I can delete the old ringtones that I created for free and Apple won't let me use. WooHoo. :mad:
minivini
Jul 6, 2007
418
Did you have to do anything for the songs to show up as ringtones or did the "bell" just appear on your list?
I am still a little unclear how this works. If I have purchased a CD and want a ringtone, will I still have to buy it through iTunes, or will it simply recognize the song? Is there some tab or button to get iTunes to check my library for potential ringtones? I still can't believe that not one of our 4000 songs is available...
Thanks!
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Unless you've previously purchased the song FROM iTunes then you will NOT be able to make a ringtone out of that song. I haven't purchased any of my songs through iTunes so I will not be able to make any (legitimate) ringtones using iTunes.
SpongebObiWan
Aug 25, 2007
218
See mediarite's post above:
"Right-click on the header bar across the top of your music library and select Ringtone"
Once you open up the menu by doing the above and click on "ringtone", a new column will appear on you iTunes with a little bell in the header. Scroll through your music selections to see if you have any with a bell. Those are the songs you can make ringtones from.
DRabbit
Jul 2, 2007
383
I feel like this is my first REAL gripe with the iPhone. I've been patient about updates, and though ringtones aren't all that important to me, I did buy one and try it out.
First off, it seems a little buggy when you first get it going. It did ask me if I wanted to see what songs were available and I said yes. I can't tell you exact percentages, but of about 2000 songs I've bought through iTunes, VERY few are available as ringtones. Okay, no biggie... that will grow as time goes on.
BUT, I wanted the new Paul McCartney song - you know, "Dance Tonight"... the one in the iPod commercials and the one Steve actually demoed in his keynote. Well guess what... that one isn't available... ARGH!
Okay, no biggie... I'll pick a different song.
So I did. Devils & Angels. I make the ringtone, all is good.
Sync it to my phone. For the most part, all is good in syncing.
But it SOUNDS LIKE CRAP. I'm assuming it has something to do with the way they recompress it to make it a smaller file size, because while regular music through the speakers doesn't sound great, it sounds 100 times better than the ringtone.
None of this is a deal breaker for me when it comes to the iPhone because, like I said, ringtones aren't all that important to me... but come on... Apple has, in part, become known for their music store, so the least that could happen is that the ringtones sound decent. No, I don't expect superb quality, but not really CRAPPY either.
minivini
Jul 6, 2007
418
Thanks. This is bad news, but not altogether unexpected.
Jagbomb
Jul 23, 2007
17
Minneapolis, MN
Zero of my 2,400 songs are available for ringtones. If I buy a CD, I should have the right to take 20 seconds from any song and use it as my ringtone. Not cool Apple. Not cool.
minivini
Jul 6, 2007
418
My biggest gripe is that a dollar for a ringtone in addition to a song purchase is too steep. I've never complained about $1 songs or $1.30 DRM free songs, but another $1 for ringtones is too much...
Austinsdc
Jun 2, 2007
97
Help please :)
K...so i bought 2 ringtones, both had the little bells. I paid for these on the iTunes store. When trying to sync to my phone it tells me that it cannot sync, because they are protected files and i do not have permission to play them on this computer. I bought both the song and then created the ringtone using iTunes and then bought the ringtone! what the heck?
You have to reauthorize your computer, than they will sync.
mediarite
Jun 20, 2007
97
ColoRADo
Make sure you select "Authorize Computer" under "Store" in iTunes.
Austinsdc
Jun 2, 2007
97
Thanks guys! I had thought of that, but i always have used this computer and i don't get why it would be unauthorized since they let me BUY them on this computer.........weird :)
AquaHump
Jul 30, 2007
17
DE
I put 2 tones on today just tp play with it. If you don't know what you are doing it can be a little convoluted. First you have to turn the ring tones on in your view options and then you have to authorize you computer. Then you find a song with a bell you like then you buy it then you right click it and go to create ring tone and select that then you have to chose the bite and the langth of the bite then you buy the ring tone.
What I don't like is if you want to do use the same song for 2 diffrent tones then you will have to pay anthoer buck for the 2nd bite you take from the song.
bsharp
Jun 21, 2007
351
Atlanta, GA
If you bought the CD, you didn't buy the song from Apple. They can't help you.
DanUC6
Jun 2, 2007
136
I got the same thing...it was like i had to re-authorrize my computer again?!?!?!
