Ringtones w/iTunes 7.4.3.1
dstaysniak
Oct 4, 2007
I have about a dozen ringtones that I converted from .wav/.mp3 to .acc that I had installed prior to the latest firmware upgrade. Of course they were wiped out. I have tried to import them into RINGTONES in iTunes 7.4.3.1 and they will show up in Music and sync to the iPod section which I could care less about. Any suggestions on how to get them to show up and be useable as ringtones?
Aug 28, 2007
348
downgrade
apptapp
sendsong lets you apply songs in your iTunes library as ringtones so put the ringtones in your library and set it as a ring through the fone
iPhobos
Jul 25, 2007
201
I have 1.1.1 on my iPhone and iTunes 7.4.3.1 . I am just looking for away to get ring tones on the phone without using jail break and what not again.
jpm
Aug 5, 2007
212
Since you have 1.1.1 you either have to buy them through iTunes, downgrade your phone and iTunes versions, or read the threads on the progress in breaking the 1.1.1 software.
scandalex
Sep 16, 2007
771
One question- if you downgrade from 1.1.1 to 1.0.2 does it remove iTunes wifi store?
