Rintones on 1.1.1 help
Jun 7, 2007
545
Queens, NY
so I followed "the guide" on modmyiPhone.com to "put" ringtones on my iPhone
so i did what they said....made the ringtone.m4a and the spoof.m4r file. now that file is just a blank text document? and yes i did modify the ringtone.plist and changed it the way they said to do....so what did I do wrong? the ringtone does not show up...i used winscp to place it where it had to go...the song i made into a ringtone...yes it was made into a 128kbs aac file and the track length was 27.453 seconds.... so where did i go wrong? any help would be nice.
patrick_83
Oct 11, 2007
310
Illinois
I just used Song Sender, which i downloaded with installer, to instantly make a ringtone out of a song directly on my iPhone.
Tinman
4,334
183
Aridzona
I am using SendSong 0.17 Experimental from here:
http://ericasadun.com/ftp/Applications/SendSong/
This has worked for me, and it even creates the spoof .m4r file. Ringtones are still blown out after syncing, but I use a Tapp command to restore my working plist.
Just add the appropriate ringtone (has to be a .m4a file) to your iPhone playlist, sync, and then run SendSong to send the song to ringtones. Works for me on 1.1.1.
Mike
patrick_83
Oct 11, 2007
310
Illinois
I havnt updated to 1.1.1 yet so I'm not quite sure how it handles stuff like that.
thegasguru
Jun 27, 2007
180
This thread will help a lot. Read the whole thread, especially the file naming info on page 4.
http://forums.everythingicafe.com/threads/custom-ringtone-for-1-1-1-for-pc.13068/
PS - the spoof files do not have to be named "spoof" (see above thread). Also, although the spoof files are zero byte (empty) txt files that you create with Notepad (or whatever app), they SHOULD be named with the .m4r extension.
EvilRufusKay
Sep 28, 2007
30
Mike
Is this an app for the phone itself using installer? I cant get it to run on my pc....
EvilRufusKay
Sep 28, 2007
30
No it runs on the iPhone itself. The iPhone has to be jailbroken to do so.
Mike
Sorry for the lame question I am about to ask but... How do I go about loading the app into the installer?
Mr. TinMan Sir,
Thank you very much for your efforts and time in helping those of us that like to mess with gadgets that we know little about. I am an Engineer but without the help of yourself and others like you I would be stuck with a stock phone. Thanks again!
SoleAddict23
Sep 16, 2007
46
Mike
is this the same SendSong under installer on the iPhone? because through installer it reads SendSong 0.09.
but i downloaded the SendSong through installer, am i suppose to go with the SendSong 0.17 experimental? is it suppose to work with PC, windows users?
i've changed the appropriate ringtone that i want for my iPhone into .m4a but whenever i try to drag into my iTunes playlist to sync into my iPhone, it won't let me. is it suppose to be .m4r?
EvilRufusKay
Sep 28, 2007
30
Yeh I am still having trouble myself. From what TinMan said, you download the experimental via a PC then send it to installer via WSCP. However, when I access the app on the phone it just hangs on a white screen. I must be screwing it up somehow...
mikelarry
Oct 10, 2007
I believe you must install version 0.09 from installer first, then use ibrickr/winscp to install the later version. HTH
EvilRufusKay
Sep 28, 2007
30
Look at that! 1 post and already thanked! I will give it a try. Thanks again!
Tinman
4,334
183
Aridzona
You need to set the permissions first. Open the SendSong.app folder via WinSCP, right-click the sendsong file, choose Properties, and enter 0755 in the octal value.
You should then be able to run it.
BTW: SendSong is up to 0.19 right now. It can now use MP3s for ringtones.
Mike
SoleAddict23
Sep 16, 2007
46
^^ yesss! thanks for the heads up on the new SendSong update. :cool:
Jun 7, 2007
545
Queens, NY
Mike
Well i did what you said, installed sendsong and it did work. The song appeared in my sound list in settings but even when i select the tone as my default tone it does not play when a call comes through, just a stock ringer plays. Any thoughts on that? The song does play when highlighted but not when a call comes in or even if I assign it as a tone for a contact....do i have to restart the phone?
Sep 14, 2007
sendsong 19e is on installer now for 1.1.1 iPhones
Use sendsong .09 if you have 1.02
Use sendsong .19e if you have 1.1.1
Tinman
4,334
183
Aridzona
Yes, this is common when adding ringtones in 1.1.1: they show up in settings but do not play. You can either try renaming the files, and editing the plist to reflect it, or deleting the ringtone and try installing it again.
If a ringtones plays fine in settings, but doesn't play for an incoming call, reset the iPhone (turn it off, then on).
Mike
Doby45
Aug 21, 2007
543
Powder Springs, GA
Just for confirmation Tinman is 100% right on this. I just downloaded the newest Sendsong for 1.1.1 and was able to send the ringtone to my phone and assign it and could play it in the ringtone selection screen. But it would not play when the phone was called. Rebooted phone and now all is good. Thanks Tinman.
