safe to use cellboost products with iPhone?
iphone62907
Jun 25, 2007
100
they make disposable and rechargable battery things for iPods, but I can use it safely with my iPhone, right? Also there is a thing that you plug into the iPod and it charges it using triple A batteries, can I use that with my iPhone? Will either of those overcharge the iPhone battery? Thanks
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I use the Tune Juice product from Apple for both my iPod and iPhone with no problem, so I would imagine these would work as well. It says that it is compatible with the iPhone so I'd give it a try.
iphone62907
Jun 25, 2007
100
yeah but something like this is nice
iphone62907
Jun 25, 2007
100
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
You should be able to plug your dead iPhone into one of the above and have it work and partially charge with no problem. It will likely charge if it's turned off but it will be sustained on if you're wanting to use it and probably will not charge very much.
