safemode
bev green
Oct 18, 2012
i was on the phone to my daughter when in mid convo my phone switched itself off and when it restarted it said it was running in safemode ive never seen a message like that before so i clicked help and it said just click reset safemode which i did but now cant ring out on my phone any one help please?
JON35Y
Oct 16, 2012
87
Hold power and home button until it switches off and back on to the Apple logo. Try that. If that doesn't work try restoring your phone.
Sent from my iPhone 5 using Tapatalk
Thread moved to the jailbreak forum.
Most people who jailbreak have experienced this at least a time or two. I only worry about it if it happens frequently. It's usually caused by an incompatible app or theme. If you recently installed/applied something, it could be the cause. If a respring or reboot doesn't fix it, try a hard reset. If that doesn't fix it, try uninstalling what you last installed.
To do a hard reset, press the home and power buttons at the same time, ignore the slide to power off and let go when you see the Apple logo.
