Saving Attachments
hong kong fooey
Jun 27, 2007
I was emailed a PDF file and a JPEG, both items downloaded fine and were viewed fine. I figured since downloaded off my POP account that they would be saved on my phone. But when I went back to view them (with no connection wifi or edge) I was not able to view the files. Now if they are moved to the sent box then you can go back and view them, just not from the inbox. So my point is, any way to create say a "saved items" folder to keep downloaded items accessible outside of wifi or edge coverage (ie. an airplane)?
pb30
81
Minnesota
I don't think you can create a local folder just for the phone. You could try using the Drafts folder, you might have to change it so it doesn't use the draft's folder on the server
