iMac Saving files to a folder
Chicksgirl
Dec 31, 2011
On my PC I could save files directly to the folder that I wanted it in.. I have not been able to do this with my Mac. I have to save it to a folder that the Mac allows me to enter and then drag it to the embedded folder. Any ideas about a way around this?
emhcee
Apr 4, 2008
246
It sounds like you just haven't enabled the more detailed save dialog... Not knowing which app you're saving from, how about this: When you click to save something, next to the dialog box where you can set the name of the saved file, you should see a little down-arrow icon. Clicking that should open more details in the save window and allow you to select the folder of your choosing, wherever on your machine you'd like to save the file.
