saving iTunes library
May 19, 2008
i took the time to attach all the artwork etc and if you delete the songs and put them back into the the library you have to do all of it over again is there any way to back it up barring a catastrophe
Thanks Matt
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
If you "consolidate library" in iTunes (on a Windows Machine) it will copy all the music and artwork to the iTunes folder under "my documents/my music". You could then burn that onto a DVD (or several depending upon how much music you have) and that would give you a backup of the music to include artwork.
