SB rotator conflicting with Bigify
TheDude1120
Dec 1, 2009
373
SB rotate makes all of my icons freakin huge because I have Bigify installed...Is there another app I can use to shrink my icons that is compatible with sb rotator?
Maybe you should look for the app Smallify. ;)
Seriously, though, Shrink is worth a shot.
TheDude1120
Dec 1, 2009
373
Lol I was using shrink but it changed the color of all the text on my sb back to white... I like the red I have tho
You can still change the color of the app icon text if you're using Shrink.
I tested this out a while back by editing the font color with the Illumine theme. Save the info.plist to your desktop. Open it with Notepad and edit the string that contains UndockedIconLabelStyle, adding in a new html font color of your choice. Replace the file and respring.
