Sbs airplane toggle?
smittylube
Feb 19, 2008
255
Silicon Valley
Does anyone know
If the airplane toggle for sbs will stop the message
That happens when I plug into my dice unit in the car?
Steve
scottjf8
Aug 12, 2008
528
No. The airplane toggle turns the phone "radio" off
smittylube
Feb 19, 2008
255
Silicon Valley
I looked closer at the message- it says this accessory is not made to work with the iphone- then it asks yes or no do you want to turn on airplane mode, you wont be able to receive calls etc.
. I always hit no. is there a way to disarm the message?
This happens everytime I plug into my dice unit for my car.
I guess I need to contact them.
scottjf8
Aug 12, 2008
528
It's saying that because the device (a charger, for example) is using the old Firewire pins and not the USB ones. It's a new thing with the 3G.
You can obviously still use the device, but it won't charge the phone.
And I don't think you can disable that message.
smittylube
Feb 19, 2008
255
Silicon Valley
They did come up with a new cable so it does charge now - but I think you nailed it as it does support both new & old style of charging. that may be why it still gives the error.
I had been hitting no everytime but I did find out if I don't do anything it will go away (the message) SO I guess no worries.
