SBSettings
Dec 26, 2008
29
Hello,
I am a newbie to jailbreaking however everythings working fine, but i have downloaded SBSettings and its showing in under installed, but is not showing on my springboard, any ideas? I have tried removing it and installing it again but it made no difference.
jdk2
Dec 2, 2008
47
Stratford, NJ
Swipe your finger across the status bar or place two fingers in the same area to display SBSettings.
Dec 10, 2009
2,589
1,337
52
Clarksburg, WV
Greetings!
3GS JB'd & unlocked w/ redsn0w & ultrasn0w, 4.2.1 w/iPad baseband.
Using SBSettings, when I go into system operations > hide icons, it populates a list.
When I select any of them to hide, then scoll down the list, ones I have selected reset to on.
I cannot get any of the hides to work.
Looked at the other settings, and don't see an enable hide, so I don't think I'm missing something obvious....
Or am I?
fijiman
Feb 13, 2011
832
64
UK
They have to be "off" to hide
A quick respring also
Dec 10, 2009
2,589
1,337
52
Clarksburg, WV
Right, got that!
Problem I'm seeing is, say I slide first one in my list to off, then scroll down to slide another.
Go back up to one had previously slid to off, and it's on again.
Tried just sliding one, then a respring, no love there either....
fijiman
Feb 13, 2011
832
64
UK
Reinstall sbsettings current version is 3.3.1. Hopefully this will fix it? Good luck
