Scratching?
lman
Oct 18, 2007
632
So I have read several threads about the Agent 18 case and heard it damages the iPhone? What exactly do you mean? Is it slightly scratching the back? Is it only scratching it if you drop it? Is there anything you can do so that it doesn't scratch the phone while its on? (heard someone say they were using a screen protector on the back)
My second question is, are either the Agent 18 case or the Switcheasy capsule sold in the Apple store? If one of them is, i think i'll go with that one as i'm a big case fan when it comes to something i want to protect.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
You need to really have the phone clean before you install the case. The grit makes scratches. Plus after on for a while the attracted dirl-lint can scratch. Do a search and read for yourself.
lman
Oct 18, 2007
632
makes sense, i just got my phone so there is no grit on it at all
Gom33
Nov 9, 2007
52
i got scratches after a little while on the chrome, i bet it was dust/grit little things that would get caught in the case itself... now i have a capsule case and i don't think i will have that problem...
oh, my scratches are mainly on the bottom chrome part... why did they have to make them chrome? wish it was like the touch's...
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
If you have some skill and time, you can tape off the phone leaving the bezel exposed. Then take a scotch brite and start scraping, and you end up with a matte finish.
Gom33
Nov 9, 2007
52
are you being serious? lol... if so, did you do it to yours and do you have any pics?
guest 5
Jul 5, 2007
614
i don't have a problem with my agent 18 case scratching my phone. but, i cleaned the phone thoroughly before i installed the case and about once a week, i take the phone out of the case, clean it and clean the case and reinstall.
snowbred
Jan 5, 2008
My case scratched the aluminum back. Seems inside the case there are two parallel lines that go down the case, if i rub my finger over them i can feel them sorta sticking out. I just got another iPhone i'd like to buy the case again but im scared its going to scratch the phone again. I may try the switcheasy capsule case instead, but im also worried it will scratch the aluminum. I may just go with the contour showcase
lman
Oct 18, 2007
632
yeah i do like the agent 18 case, but i am planning on going into the store and getting the contour case as well
xsbx
Jan 5, 2008
40
Eh whats the next best thin case because I would be furious if I found out the case scratched my iPhone.
almarlimjr
Jan 4, 2008
111
I've had the Agent 18 case for about a week now. Took it off to check on the phone and I saw tiny scratches on the corners of my bezel. Which was hard for me to believe because I keep my phone clean and in a leather holster.
Don't get me wrong the scratches are only visible if you're inches away. But then again, I'm obsessive compulsive when it comes to phones.
I'm thinking of taking it back and getting the Incase Slicone case.
Anyone with the Seidio Rubberized case experience any scratches on their phone?
snowbred
Jan 5, 2008
I just ordered the artwizz seeclear case. Maybe I will have better luck. I'm so anal with this phone I'm on my 5th case.
Marcos
Dec 19, 2007
140
Phoenix, AZ
KNK is right. I made the mistake of not cleaning my iPhone before the case went on and it left some tiny scratches at the very bottom of the chrome piece.
