screen dead
mabext
Mar 4, 2009
help me! iPhone screen is dead but it does ring when someone calls
6,682
49
More information is needed.
Phone Version
Firmware version
jailbroken Yes or No
Ever been dropped?
What were you doing before it died?
28,365
5,507
Try rebooting it by holding the home and power button and ignoring the red slide to turn off switch. If that doesn't work, you may have to restore it in iTunes.
mabext
Mar 4, 2009
did everything, unfortunately nothing works,
tried to call from my landline, fon rings but nothing is showing on the screen its totally dead
6,682
49
Connect to iTunes and sync, if the display still doesn't show anything, restore. If it still doesn't show after that... It's most likely hardware.
If it's within a year of purchase, or 2 years if you bought Apple Care, then I would tell you to make an appointment with Apple.
If it's not under warranty, then it might cost you to get the repair done. If that is the case, shop around and I am sure that you will get a deal.
mabext
Mar 4, 2009
K
thanks 'preciate it
