screen name
Matthew
Nov 28, 2008
My iPhone used to be recognized as 'iPhone of Matthew' for syncing purposes.
Recently I discovered that the iPhone (or my Mac) has changed this into '*'.
Just the asterisk, nothing further.
Everything works fine, so there is no problem.
Yet I would like to rebaptize my iPhone again with my name. Is this possible at all? And how do I do it? (Not to mention: Why did this happen?).
Thank you for your reply/help.
Matthew
Marianne
2,326
29
Massachusetts
marianneschultz.com
I'm not sure why this happened, but it's easy to change. Just click once on the name of your iPhone in the sidebar in iTunes while it's connected - it should become highlighted in orange (or whatever color you have set your Mac to show when text becomes editable) and then you can type whatever name you want. Press Return/Enter and you're done!
Matthew
Nov 28, 2008
Thank You!
Dear Macgirl,
Thank you for your suggestion. I tried it, and it worked.
If it is so easy to correct, this probably also explains how it happened. Many computer errors have a human cause ...
Kind regards,
Metthew
