Screen Recorder-iOS 7?
5,578
#41
Uninstall Record My Screen and FaceClockUp. There's an alternative to FakeClockUp that you can use if this works. After uninstalling them, do a hard reset and then install Display Recorder. Make sure all of the Display Recorder dependencies are also installed. I'll attach a list of them. Let me know if that doesn't work and I'll list the other few that I think might be conflicting with it so you can test uninstall them one at a time.
liberated
Jul 19, 2007
3,238
488
#42
Good deal, I'll try that now and report back!
liberated
Jul 19, 2007
3,238
488
#44
Update: changed settings to QuickTime and now it's working normally. Thanks for the help and the great app suggestion Europa.... Another thing, what's an alternative to fakeclockup ?
5,578
#45
Update: change settings to QuickTime and now it's working normally. Thanks for the help and the great app suggestion Europa.... Another thing, what's an alternative to fakeclockup ?
HiddenSettings7. You open it through the SpringBoard Settings bar in Control Center. You can use the settings Napoleon posted here to eliminate the lock screen lock/unlock fades. I use these settings for animation overrides:
