SD Card Question
BigD234
Nov 12, 2007
Hi All,
I admit it I don't know what I'm doing wrong. I have a 8G SDHC card and a reader. My iMac recognizes the card but will only allow me to read only. I am trying to load music onto the card. What should I try? Any help would be appreciated.
6,682
49
Well, I don't own either a iMac (or any mac) or a SDHC card, but I can tell you that with a regular SD card, there is a switch on the side that makes it write protected. check to see if there is a manual write protection switch on the card. Otherwise see if you can view the properties of the card and change the setting from read only to read/write
