SD Card Reader
Kabeyun
Jan 10, 2007
665
Northeast US
There's also this guy for less than half the price. (Who'd have ever thought I'd say that about an Apple product?) You'd also be able to use a camera with CF, Mem stick, XD, etc. :cool:
It's a good bet (but no certainty) it'll be iphone-compatible.
-K
madgadjt
May 21, 2007
the only thing i want to know is, if it works, can it get movies from it :) 8 gigs wouldn't be so bad if you could just keep your movies on 15$ sd cards
wjp09
Feb 25, 2007
2,559
25
NJ
Wow I cant believe I missed this thread. Anyway maybe someone will crack this to allow the storage of video/music.
iksnae
May 29, 2007
another possibility...
Apple could be planning a storage upgrade in the near future. as a avid mac user i know Apple will release a much better version shortly after you run out and grab one. flash media technology is advancing. it's getting smaller and cheaper... for example:
http://gizmodo.com/gadgets/peripherals/Samsungs-32gb-flash-drive-hard-disk-killer-161923.php
my problem the ipod was the hdd. i just don't think a hard drive should be spinning and bouncing in your pocket. in my experience the drive usually crashes and eventually has to be replaced.
though i'd love a removable media port... i think Apple is headed in the right direction.
MikeMirage
Jun 9, 2007
the problem with flash media is that it can only be flashed so many times and that is way less than the amount of times you can write to a hdd without failure.
wot_fan
Mar 7, 2007
586
51
Chicagoland
web.mac.com
This is true, but not really a big deal. I believe the iPhone uses Nand Flash (same as the iPod Nano). If so, it has a life expectancy of about 1 million cycles. I doubt the flash is going to fail before some other component does. No matter how you slice it though, the benefits of flash far out weigh the benefits of HD in a mobile device.
AlphaStrike9
Jun 14, 2007
19
I just ran across this SD card reader for the video iPod. If this works for the iPhone, it will be a great way to transfer pictures from your stand alone camera (for emailing). It is a little pricey though.
If it is not compatible, I am sure an iPhone version will be developed eventually.
it probbably will work i'm about 99% sure that jobs said in his first keynote that it has the same plug at the bottom like all the other ipods just don't go and get one right now.
minivini
Jul 6, 2007
418
Apparently the iPhone is working with most of the speaker accessories that has a dock/cradle. One person has posted on another forum that she took it into Best Buy and plugged it into the Bose iPod speakers, Klipsch, and others - and it worked...
