SD Possibility?
marbanno
Jun 6, 2007
I'm just wondering if and SD card may be a possibility. I know it doesn't quite make sense but my reason is twofold. One, Top view pics from engadget show a possible section (not the ipod hold tab) that looks like it may allow for a SD. Second, EBcases is offering a pre-release iPhone case that has a space for an SD card. Of course this may just be a guess on their part but the pics of the cases seem to be true. Just speculation.
007youknowme
Jun 6, 2007
21
that slot is probably a sim slot. I wouldn't expect Apple to have a sd slot, that's not their style if you look at past/current products
marbanno
Jun 6, 2007
Good point
Good point. Good point. Forgot about the sim. And I agree it is not there style to have an SD.
macinnw
Jun 2, 2007
26
The keynote where Jobs announced the iPhone said it was a SIM slot and there is no mention on a SD or anyother media card slot.
This was my deal breaker.
joe
May 5, 2007
1,113
Could an SD reader be attached to the iPod port if one were created for it?
joe
May 5, 2007
1,113
For me that would defeat the purpose. At that point i'd just connect it to a laptop.
I'm not sure I understand. I was thinking of a small device that attaches to the iPod port where I can insert a small memory card that holds 8/16/32G more movies/shows/etc, all accessible from the iPhone like its own internal storage. This sounds a lot better than hooking up to a laptop. Or did you mean for transferring data to the iPhone?
wjp09
Feb 25, 2007
2,559
25
NJ
Maybe an adaptor could be made for the connection end to make the iPhone think a cpu is hooked. Sort of how they did the "hard drive" for the psp. They dummied a memory stick which lead to a hard drive.
joe
May 5, 2007
1,113
Since they exist for iPods, I see no reason why not. In fact, the ones made for iPods might even work with an iPhone. Check out this thread.
There you go! Problem solved! I'm hoping this will be an accessory that is available early on. :eek:
SmartAlx
Jun 7, 2007
1,087
I seriously doubt they will include an SD slot. Some people are confusing the slit looking thing on the side for an SD slot. But look at the official picture. It's clearly a rocker button, probably for taking pictures or something like that.
joe
May 5, 2007
1,113
Nope, it's volume. That was mentioned in the keynote. :)
marbanno
Jun 6, 2007
Yeah that is definitely looks like the volume. The SD reference I was talking about was on the top of the phone. However, I don't believe it is an SD slot rather a SIM slot...makes so much sense. And as everyone is pointing out, It is not Apple's style to go to SD, although there is a big movement in the industry to "flash" storage. I think toshiba but I could be wrong has a 64GB card. Just food for thought.
joe
May 5, 2007
1,113
Yep, the thing on top is definitely the SIM Tray. I don't think there will be a need for Apple to ever implement an SD slot. They will continue to bump up the internal flash size over time. If they expect to have the iPhone replace your video iPod this will have to happen.
macinnw
Jun 2, 2007
26
If they expect to have early adopters, they need a SD media slot.
I use my Treo 650 at work, and move SD media cards between my phone, camera and latop, as a fast, efficient way to move photos, spreadsheets and word docs around.
Without an SD media card, i won't consider the iPhone and the undisclosed cost of the required data plan. Especially since the iPhone would be on my dime and not the company's. So I guess i wait for rev 2.
marbanno
Jun 6, 2007
I'd agree with you that SD is very efficient between electronics. I too interchange between my mac, camera, 8525 smarthphone, miniDV, and pc. However, as a new mac user (only about 1 1/2) I have to say that most of Apple's stuff is easily sync almost eliminating the need for a "third" party storage. I love SD don't get me wrong and I love all my Apple products. I'm not sure whether or not SD should be a primary reason for not adopting an iPhone sooner. It seems that Apple will not be including the SD slot...hmmmm decisions...
wot_fan
Mar 7, 2007
586
51
Chicagoland
web.mac.com
If I had to bet, I think you are going have to wait a lot longer than for Version 2. As much as I would like Apple to add an SD slot, I don't see it happening. If you really want an iPhone and SD support is a must for you, I think your best bet is going to be getting an SD reader accessory (like this one for the video iPod). If that solution is not acceptable to you, I think your going to have to find a different phone :(.
jmcd
Jun 12, 2007
sim card
I hope it has a sim card. I HATE transferring all my contact information from old phones to new phones. I know that iPhone has an option to sync with your address books from outlook and stuff - but I've never bothered to put it all in there.
joe
May 5, 2007
1,113
You can typically sync your current phone to your Mac, then sync your Mac back to your new iPhone. That makes it pretty painless. :)
Imahottguy
Jun 11, 2007
Lansing, MI
www.freemod.net
With 4gb or 8gb of storage, why would one need an SD card? If for businesss purposes, wouldn't one have a data plan already? I have a Motorola ROKR E6, and I couldn't tell ya the last time that i removed the SD card.
