Searching mailbox
brdmsd
Jul 18, 2007
169
19
How do you search for a past message in your mailbox with IOS 7?
Sent using iCafe app
RBNetEngr
Jun 17, 2013
170
27
To search:
- go to the mailbox you want to search
- touch anywhere on the mailbox screen and drag you finger down a bit. A search box will appear at the top of the message list
- type your search criteria
Hope that helps.
-rb
-rb
28,365
5,507
There is a search bar above the most recent message.
