Secret-Lock
Dec 15, 2008
5,386
340
Pensacola, FL
Very cool tweak that I just tested out and it works perfectly. If you worry that someone will get into your phone even without a computer/iTunes, this will make that impossible unless they know your secret hand/finger gesture.
If you have/use touchID, you can still use that to unlock your iPhone, but I'm going to use this tweak as it's cool and just in case I lose my phone, but if you know me, I keep my iPhone with me 24/7. :p
5,578
They definitely aren't impossible to bypass. You can disable Cydia locks through the file system on a computer or by booting into No Substrate mode.
Dec 15, 2008
5,386
340
Pensacola, FL
I was thinking that "If you worry that someone will get into your phone even without a computer/iTunes, this will make that impossible unless they know your secret hand/finger gesture." was saying that they could use iTunes to bypass. "even without a computer/iTunes" However, I did not think about booting into safe mode. My bad! But nonetheless, I like it...although I rarely use it myself. It's just a safety measure to take just in case.
