Sell my phone.
Nur2652
Aug 1, 2010
114
Just wondering, I want to upgrade. Should I get the 4S, transfer everything over from my iPhone 4. Then reset 4 to factory settings and sell it? Is factory settings enough or do I have to do something else? I want to make sure phone is clear before I sell it. Thanks.
iphonewarrior
13,847
699
If I was you I would back everything up to iTunes. Sync your iPhone 4S then restore your iPhone 4 - but don't restore from backup.
iphonewarrior
13,847
699
When you've restored your phone, you will be prompted to restore phone from backup. You don't want to do this as your backup will go back onto the phone thereforee not erasing the device.
