series 5 or 7 from any kind of identification number on box?
chenyichung
Jun 30, 2007
47
So there’s no way to tell what series screen your iPhone is going to have right?
I want one with a series 5 LCD
How do I tell when my iPhone was built, like what week, I thought I read somewhere that it’s part of the serial number or something
Or you know how you can type your macbook or macbook pro’s serial number into a small application written by someone, and it’s able to tell you when and where your laptop was built, is there anything like that for the iPhone?
geordisjd
2,442
"You need to put the iPhone into field test mode. Type *3001#12345#* into the number pad of the phone and press call. Then select versions."
I'm quoting somebody, I think.
Jun 27, 2007
198
I have learned from numerous places (including the Apple store) that both 5*** and 7*** series are still being produced, so it doesn't really matter when it was built - there is still a chance of getting either. As for telling which box has which series LCD, the only way is to turn it on and look at the screen or use the code.
mceis
Jul 9, 2007
Trial and error is the only way my friend. I had a 5 and a 7, both were manufactured in the same week at the same plant. There is no correlation with the serial number.
geordisjd
2,442
Really, don't guess and enter the above number, stars and all, in the iPhone you want to test. Send. You'll get a screen that that "field test" that gives you all kinds of info on the network, cell, GPRS, etc... The last choice is "Versions". It will give you a number for your LCD Panel ID. The first number (5 or 7) will give you the series.
Indy
Jul 29, 2007
2,921
41
Can you punch this code in without activation?
The only reason I ask is because, I guess you could just tell them you're about to spend $600 on this phone and I want to make sure I get the screen that I want, thereforee I need to punch this number into all of your units until I find the one I need.
Lol, now that I typed that out, it sounds ridiculous! Whew, time for bed.
HELPmepLox
Jul 15, 2007
So.Cal
but one thing for sure i got a series 6 uhh... but im good because the screen actually looks better then both of them from what ive seen.
geordisjd
2,442
I once went to my local Apple store and installed a not-so-legally made Star Wars III screen saver on all their display computers (about 12 of them).
If I can do that, you can check a few iPhone units.
jeepshots
Jul 10, 2007
68
So which one is desired? I did the code and see a series 5 panel ID...
ahaxton
Aug 5, 2007
235
I went to get a new iPhone yesterday, and it was also a 7 screen as my first one I bought at another store. There was a guy who had an iPhone too and I found out his was a 5. I didn't mention it, but I liked mine better than the 5. Something just seemed different.
j2chulo
Aug 25, 2007
27
*runs*
Search and you will find enough reading for a few weeks :eek:
*runs* what do you mean by that? i try search the forum for lcd and nothing comes on. if anybody know whats the difference just post it here. i guest my its a series 5 because it start with a 5. 575.....
eufo
Aug 22, 2007
67
Miami
There was some article about the panels starting with 5 looking better than the ones starting with 7.
Mine starts with 5 and my buddy's starts with 7. They both look awesome. Neither is dark or fuzzy.
The only difference we could see is that you can see the LCD grid a little more in his and there is a slight color/hue difference (mine slightly more blue, his slightly more red). But these differences could only be seen if they were side by side.
The whole thing is a joke.
geordisjd
2,442
how do you tell when your iPhone was built?
what part of what number is it on the back of the box?
I'm afraid it's not ON the box, but IN the box. You got to get them to open the box for you and check the phone itself.
but there is nothing on it that will tell you what LCD# is inside.
j2chulo
Aug 25, 2007
27
thank for your clarification. yeah my screen look preaty good
