Serious touchscreen issues with my iPhone 5
49ers#1
Sep 25, 2012
41
Tampa, Florida
The following video will show you what's going on with my iPhone 5 (3rd phone). Yesterday (1/26/13) I paid a visit to the Apple store and had my second iPhone replaced due to my screen. The guys at the Apple store said its hardware issue. So far, this issue only pops up when my phone is plugged in.
iPhone 5 touchscreen problems
https://http://discussions.apple.com/thread/4326234?start=0&tstart=0
Again, this is my second iPhone 5 (within 2 days) I'm having the same "hardware issue"..... Does anybody have any idea what's causing this problem?
Sent using iCafe app
49ers#1
Sep 25, 2012
41
Tampa, Florida
I'm currently using a Lifeproof case on my phone. So it wouldn't be that, plus it only occurs while my phone is charging... This problem is really annoying! I'm thinking its got to be the cable that came with the phone...
jmp316
Jul 10, 2008
1,048
141
Did you restore as new phone or from a previous backup. If it happened with two phones, it may be a corrupt backup. Try a restore as a new phone.
49ers#1
Sep 25, 2012
41
Tampa, Florida
No not yet. Just to clarify, this touchscreen problem didn't start right after I restored my second iPhone with my latest backup. If my backup was corrupted from the start, wouldn't I have noticed it from day 1?
This whole situation confuses me due to the fact this problem only occurs while my phone is plugged in my bedroom. I've tested my phone out by charging it in my car and from MacBook Pro. I couldn't replicate the issue. Again, it only happens in my room...
49ers#1
Sep 25, 2012
41
Tampa, Florida
"Sigh" my phone has been plugged directly into the outlet minus the extension cord for at least 20 minutes and the touchscreen issues are back.
Going to try to wipe my phone and start from scratch.
iPhone 5 (3rd phone) 32g - black
Go Niners!
Assuming you restored to factory settings, aren't using a screen protector or LifeProof that might be interfering with conduction, and your hands are dry, you'll need to have this phone replaced. Set the new one up as a new device and only use Apple charging cables.
Screen protectors and a LifeProof case shouldn't cause problems like these, but since you're having problems with the touchscreen you'll want to avoid them while you're testing.
JON35Y
Oct 16, 2012
87
I have seen a similar issue but it was my 4S and it was when it was charging from my friends car charger. The screen worked but you had to touch a different part of the screen to open your selected app. I'd say definitely try a cable first. The chances of having 3 faulty iPhones with the same issue is very unlikely
49ers#1
Sep 25, 2012
41
Tampa, Florida
Just got back from the Apple store. I had my charger and lightning cable replaced but kept the phone to do more tests later today. The techs believe its a bad charger or possibly the outlet in my wall going bad. I'll update after I've done some more tests.
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
Be careful with that. I knew a friend that the outlet went up in flames and almost burned down the house.
49ers#1
Sep 25, 2012
41
Tampa, Florida
Thanks for the heads up. Lets just hope it was my charger that went bad and not the outlet.
I seriously do have to give the employees at the Apple Store credit for being patient and willing to help me out with switching out my last phone and the charger + lightning cable.
49ers#1
Sep 25, 2012
41
Tampa, Florida
I've been testing the new charger / lightning cable out and everything seems back to normal. I'm guessing it was a faulty charger that was causing my screen to go crazy.
iPhone 5 32 gig black
(3rd iPhone 5)
Go Niners!
  • Like
Reactions: RoofMonkey
