service help
Apr 28, 2008
my iPhone 3g won't receieve any service with a sim card inside. It's jailbroken on 2.1
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
Take the card out and put it back in. Or you could put a small piece of tape on the back of the sim card so that it will "push up against" the phone nice and tight when you slide it back in. If that doesn't work...RESTORE.
Apr 28, 2008
i have tried to restore and rejailbreak before, but it still didn't work.
OJsakila
Jul 15, 2007
3,021
Well you're in trouble. Try restoring from a DIFFERENT computer and a new fresh iTunes. Then go back to your computer and sync. If that doesn't work, take it in to an Apple store or ATT.
