Setting up Comcast email
gary88
Sep 11, 2007
100
Chicago, IL
Does anyone else use Comcast for email and know how to get the settings to set it up on the iPhone?
Jason14
44
i do....
go to settings then mail then add account form there select other
ACCOUNT INFORMATION
Your name
and your camcast.net email address for address and for description
INCOMING MAIL SERVER
Host Name:mail.comcast.net
then your user name and password
OUTGOING MAIL SERVER (SMTP)
Host Name:smtp.caomcast.net
Username and passwprd optional
gary88
Sep 11, 2007
100
Chicago, IL
Worked out perfectly, just forgot to set it to POP the first time I tried. Thanks!
stevetim
Jul 20, 2007
606
with Comcast, you might have to use port 25 on the smtp to get your emails through both wifi and edge. If you use just wifi, you don't need port 25. But to access Comcast's email server through edge it has to use port 25.
smtp.comcast.net:25 is the correct setting.
It's what I use and have used since day one.
todd1010
Jul 15, 2007
34
I have comcast email and I didn't set any port numbers and I've been receiving my email since day one perfectly.
stevetim
Jul 20, 2007
606
Ya, some people have luck with standards. I didn't. It may have to do with locale, and the server settings for different customers.
todd1010
Jul 15, 2007
34
That's good to know though!
Donna GG
Aug 26, 2008
can't send mail
can receive mail on my new iPhone, but get msg: "cannot send mail; sender's address is invalid." think using this Port 25 would fix that ... or?
Thanks for any help!
