Settings Icon missing, please help me
  1. croccolo
    croccolo New Member
    Jan 12, 2008
    Hi, i installed today the application Extended Preferences (Will Strafach) and the settings icon it's now missing..... how i can restore it ?
    I tried to unistall Extended Preferences but the icon still missing.....
    Please help me.
  2. tundra
    tundra New Member Bronze
    Jul 15, 2007
    I upgraded to 1.1.3 jailbreaked by devteam and I am having the same issue. Its driving me nuts. I see the preferences.app folder when i connect to iPhone. Anyone have any suggestions?
  3. Avatar
    Sponsored Advertisement
  4. GSA190
    GSA190 Member Bronze
    Oct 29, 2007
    Could it be on the other page? Like flick threw the pages..idk, sometimes its the little things.
  5. tundra
    Jul 15, 2007
    nope i actually seen it move and iTunes take it's place. It is gone. Although i see the preferences.app folder still when i connect to phone through transmit.
  6. GSA190
    Oct 29, 2007
    strange...
  7. tundra
    Jul 15, 2007
    Not so sure its strange. I am sure I must have deleted something by accident. Does not make sense though. Wonder if i could re run the 1.1.3 devteam jailbreak without downgrading back to 1.1.2 .... Perhaps that may fix the issue.
  8. Prayag
    Prayag New Member
    Feb 29, 2008
    Simple, Stupid but workable solution for Beginners!
    Guys..I faced the same issue, wrote to Will (THE DEVELOPER OF TH F**** EXTENDED PREFS), got no response and couldnt find any help across the world wide web! So i did what i have always been doing with windows when it gives way every few months...REINSTALL!
    Process takes about 15 minutes and you get fresh iPhone!
    Heres what you can do:
    1. SYNC (BACKUP) your iPhone! UNLESS IT doesn't HAVE ANYTHING OF USE TO YOU! ;)
    2. DOWNLOAD 1.1.1 firmware from Apple (Link Below) Its 1 150MB file so be patient.
    http://iPhone.unlock.no/#restore-firmware-files
    3. Download ZiPhone Software from http://www.downloadziPhone.org/
    YOU MIGHT REQUIRE .NET FRAMEWORK 2.0 if you already don't have it.
    4. Make Sure you have a Wi-Fi Available.
    5. Connect iPhone Via USB and Open iTunes.
    6. Press Shift+Restore and Select the downloaded file on step 2
    7. Wait for 5 minutes as the restore takes place. don't panic when an error message appears at the end. Just click ok and close iTunes.
    8. Open ZiPhone and Click on "DO IT ALL". Wait for 4-5 minutes as the Jailbreak takes place.
    9. At the end of process the phone will be jailbroken and unlocked. Now you need to connect to the Wifi
    10. On Safari open http://jailbreakme.com and download AppTapp. don't Panic if it doesn't work in 1 shot do it for a few times till it starts downloading the Installer.app.
    11. Onces downloaded, open installer.app add BigBoss Repositry and Install YouTube 1.1.1 Security Files.
    12. RESYNC your iPhone using iTUNES.
    13. BE WISE INSTALL WHAT YOU USE MOST. :)
    THIS MAY NOT BE THE BEST SOLUTION. BUT IT LEFT ME WITH A BRAND NEW BROKEN PHONE THAT WORKS FASTER (LIKE A NEW INSTALL OF ANY WINDOWS) AND A LOT OF EXPERIENCE AS TO WHAT I SHOULD AND SHOULDNT INSTALL.
    I HAVE DONE IT ON MY WINDOWS OS LAPTOP. I don't KNOW SH** ABOUT MAC BUT I GUESS IT WILL WORK THERE TOO! ;)
    PEACE!
  9. joshua Pellicer
    joshua Pellicer New Member
    Jun 23, 2008
    Here's what I did.
    I didn't want to wipe my ipod so I tooled around for a bit and got lucky.
    Had the same problem. Here's what I did:
    Download "Finder" application in Installer - Not sure of the source
    Open Finder and find the little nino sign "~" a the top right and press it
    Select "Library"
    Select "Preferences"
    Scroll down and find the three files that start with this:
    "com.apple.preferences."
    Select them one at a time and press "Modify" at the bottom
    You'll see "Owner" "Group" and "Everyone" lines with "Read" "Write" and "Exec" next to them. Activate all of those options so the Read Write and Exec options are blue/whatever-color-you-set-to-be-your-selection-indicator
    Now go back to your "Installer" and search for "Preferences"
    You may see a couple of "Extended Preferences" options... IGNORE THESE. That's what gave you this problem in the first place.
    Select the "Preferences" application and install it.
    That's it!
    I know absolutely nothing about computers but my ipod was already screwed up so I did this to take a chance and tinker with it and it worked.
    I hope it helps you too!
    If it works for you please post it everywhere so people can use it. If not, oh well! :)
    Best
    Joshua
  10. iAttorney
    iAttorney New Member Bronze
    Sep 30, 2007
    You guys may also want to try and install an application called "poof." It hides and unhides applications on teh springboard. I am not sure if your program actually uninstalled the settings program (probably not I am guessing). Install poof and then use the program to "unhide" the settings app. It should pop back up on the home screen. Note: poof worked great for me on jailbroken 1.1.4, so no compatibility issues.
    Hope it helps.
  11. Dickgra
    Dickgra New Member
    Apr 1, 2011
    I found a easy way to get the home screen page back. Just move to the left of home screen and search for SETTINGS then go to general then down to reset ans chose RESET home screen layout. You can find anything on the iPhone.
    Good luck
  12. Lon
    Lon Evangelist Gold
    Jun 5, 2010
    125
    Did you happen to notice you are responding to a 3-year-old Post!
    • Like Like x 1
  13. Eric Woudenberg
    Eric Woudenberg New Member
    May 25, 2011
    Wonderful perfect excellent advise. I lost my settings icon by moving it into a subfolder with iTunes. It never appeared in the subfolder, nor did it appear anywhere else. These simple instructions "undoes" that step and puts all your icons back at top level.
  14. Golden Green
    Golden Green New Member
    Aug 4, 2011
    Thanks it worked! My settings icon "disappeared" for almost two weeks  and now it's back thanks to your advise above.
Share This Page
