Settings?
HUNTER1
May 28, 2009
404
In settings under email, I have push sets on ''ON" and I have fetch checked every hour. Can you tell me how those works? And manually as well? thanks
smknSRT8
Oct 13, 2007
1,325
Only have Push enable if your email provider (Gmail, Yahoo etc) allows push, Yahoo does push, Gmail, doesn't.
Fetch is how often you want Mail to go and look for new emails, the more frequent you set it to update, battery performance goes down.
Manual is exactly that, the only time Mail gets updated is when the application is open. This yields the best battery life.
HUNTER1
May 28, 2009
404
Ok, now I understand. I will set mine to manual, thanks
