SHIELD iPhone 3G CASE
rich9993
Jul 27, 2009
SHIELD iPhone 3G/3GS CASE
I had a Digifocus-Tough Shell bought on Amazon.com before, but the quality was poor.
The design is really weird and it doesn’t fit my iPhone at all.
Every time I touch it, I left my finger on it.
There is no non-slip design on the back of the shell, and the surface is easily scratched. It got dull after using for a while.
It looks clumsy when putting it on.
Digifocus shell makes my iPhone even thicker; when wearing jeans, I can’t even put my iPhone in my pocket.
So, I did the research again on Amazon, then I found SHIELD Polycarbonate Slim Fit Case. There are a lot of positive comments about it.
It contains a hard case and a swipe cloth for cleaning finger prints.
Smooth edge and great ergonomic design with leather paint give a sure grip and don’t leave any finger prints.
You can see the elaborate designs and excellent quality from every angle, and it’s integrated.
It leaves 2 holes for my cell phone straps, a pretty thoughtful design.
If someone asks for my recommendations of iPhone protecting case, I would definitely say SHIELD. The minimal, soft-touch and thin design with fully protection are the reasons why I love it. I would say that is the best protecting case for iPhone I’ve ever seen so far.
Moreover, the best product doesn’t have to be the most expensive one; I think I found the perfect one for my iPhone, I hope you do, too.
