Shieldzone Full body invisibleSHIED for iPhone.
nirav464
Dec 24, 2007
81
if you have this film is the touchscreen easy to access like do you have to tap the icons hard or is it normal. Also do you recommend me buying it from your experiences?
meiphones_brill
Nov 16, 2007
797
You won't even know it's there. The screen doesn't require or use physical pressure in any way (try using a tool like a pen as a stylus!)
They're very good. Having said that the original screen is quite tough on its own.
nirav464
Dec 24, 2007
81
do you think that invisibleSHIELD is the best film out there thats affordable. I mean compared to iQase and Bodyguardz?
meiphones_brill
Nov 16, 2007
797
Sorry - no idea, personally I don't like to add any bulk at all to the phone. A few scratches here are there don't bother me half as much as case does
Jun 19, 2007
33,486
4,549
Upper Marlboro, MD
One other advantage of a product such as the Bodyguardz is that the part that protects the body of the phone also provides a better grip on the phone.
6,682
49
The invisible Shield come with a lifetime warranty, and if you have to remove it for any reason, or it comes off (like that actually happens :rolleyes:) just send it back and they will send you a new one.
I have the full body shield and it rocks.
PapaST
458
Does the full body invis shield get in the way of the docking station?
PapaST
458
Nevermind... i just got my invisi shield in the mail so I'll find out soon enough. It looks almost identical in cut to the bodyguardz. Bodyguardz sends you 2 while invisi shield gives you as many as you want as long as you send them in the new one (according to an earlier post). So sounds like it's a user call as to which you prefer.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Yes Brill is right, it is optical glass.
almarlimjr
Jan 4, 2008
111
Can anyone tell me if the back piece wraps around the bezel?
And does the back piece have a hole for the camera?
6,682
49
Yes is does wrap around on the sides, there are 2 extra pieces to cover the top and bottom part of the bezel.
There is a hole for the camera was well.
