Short video clips won't upload to Dropbox
Francois
Nov 18, 2012
34
I've got 2 short video clips thatI've taken with my iPad (lengths are 9 & 13 seconds). They're suppose to automatically upload to Dropbox with a Wi-Fi connection. It doesn't matter for how long I connect through Wi-Fi, they just won't upload. They keep sitting in the device Dropbox under Photos saying "Camera Uploads (2 left)"
There's sufficient space in Dropbox by the way, only about 2% used.
Sent using iCafe app
Francois
Nov 18, 2012
34
Hmm, not sure how to do that.
RoofMonkey
Jun 21, 2010
8,894
2,058
Open drop box app and click the + sign on the upper right
You will see the option to upload here or create a new folder. If you ready have a video folder or a place where you want to upload it, navigate to that folder first, then click the + sign
When you either create a new folder or click on upload here, it should then take you to your camera roll and allow you to select the file/video(s) or photos to upload. Select the ones you want, then tap upload (top right)
Francois
Nov 18, 2012
34
Thanks, that seemed to have worked.
Francois
Nov 18, 2012
34
Hi
New problem. My Dropbox have been set to automatically upload camera roll. I just opened it up and there were 21 new photo's and it started uploading them over wi-fi.
It is now stuck and keep on saying there's 6 left and I don't know at which one it got stuck and why it doesn't want to finish uploading them all. It just keeps running until the upload bar is nearly full and then starts over again for days now.
5,578
The fastest way to fix this is delete the app. Then reinstall it and be sure to select no when it asks if you want to enable automatic photo uploading.
