should i downgrade to 05.13.04?
cadman33619
Jun 16, 2010
17
Can someone tell me the advantages to downgrading from 06.15.00 to 05.13.04....aside from regaining GPS?
thanks
hmfc-1874
Sep 10, 2011
510
34
if you are talking about baseband, then I don't think you can downgrade. Sorry
fijiman
Feb 13, 2011
832
64
UK
thanks
You don't need to build a custom firmware to update firmware.... There are no disadvantages ..... the 06.15.00 baseband fix is meant as a last ditch attempt to unlock iPhone...so reverting back to 05.13.04 is the ideal state as it's easily unlocked....
